mrarroyo
- Jul 27, 2005
I do not have my XM3 anymore, but since op-amps are cheap enough give the LM4562 a try.
http://www.national.com/pf/LM/LM4562.html
Originally Posted by Jammin72 /img/forum/go_quote.gif OK so I am officially blown away. I had assumed that the transition would take many hours of burn in to be effective. Attention Practical Devices.... If you want a giant killer for high impedance cans look to the AD8620 for your solution. First the amount of power available to the headphones with a simple chip change is fairly staggering. When going with the Stock OPA Op Amp there was little difference between the Amp and my headphone output jack on the STR-DA3000ES. Now that the chip is changed I might as well be listening through ear-muffs through the stock receiver output. There is a slight grain to the signal that was not present before but knowing what I know about burn in I'll be willing to bet this issue alleviates itself. The signal is simultaneously more detailed, more open, and more accurate. I thought perhaps I would sacrifice soundstage for accuracy but I'm wrong. Intrinsically I should have known this, accuracy in the high frequencies is the father of soundstage. I'm terribly excited at this point I will keep this amp as a portable solution and begin to look at tubes for the home. mrarroyo... Any experience to lead you to believe that there's another op-amp with a larger soundstage?!? Your call so far as it relates to a Sennheiser HD580 is nothing but dead on. I love everything about the change but I could stand a bit more warmth. If threre's a solution that provides the improvements of the AD8620 with a more tube-like character... I'm all ears. |
