ToneDeafMonk
Previously known as TheDeafMonk
LinsoulIs it still discounted on Linsoul.. or were you thinking about Amazon?
It has 9V/3A, it should work fine.Anyone know if I’d be safe using the USB-C from the power adapter of my MacBook Pro to power the XD05 Pro (in EXT mode or charge)? Or do I need to invest in a new power adapter?
This is the one I have-
https://www.apple.com/shop/product/MLYU3AM/A/140w-usb-c-power-adapter
While using sparkos could you close the enclosure or have to use it with lid open?I have an XD-05 PRO on loan for a couple of weeks and have been doing some initial testing / op-amp rolling. I'm still forming impressions so don't want to post too much just yet. It's a beast of a device and has plenty of power to drive any IEMs and probably most headphones.
I've swapped op-amps and installed a pair of Sparkos SS3602s in place of the JRC5532 op-amps that were supplied. The SS3602s *just* fit but I had to trim and file a couple of the installation legs on the underside of one op-amp as they were catching against some of the caps. Other op-amps mentioned earlier in this thread such as the Burson V5iD, Muses02 and Analog Devices op-amps will fit without any difficulty. I'd recommend using DIP8 mounting adapters with op-amps such as ADs or Muses so you don't damage the legs of the op-amps themselves. You need to be careful when extracting them directly from the XD-05 PRO op-amp mounts.
I've included a few pics to illustrate the change of op-amps to the SS3602s.
I've tried the XD-05 PRO with ThieAudio V16 and Kinera Loki. Unfortunately, my Storm is back in Singapore atm. V16 is very, very sensitive and I have heard no hiss whatsoever. The XD-05 PRO has three power modes - Eco, Normal and Turbo. Both my IEMs can be driven in any of the three modes without issue. Moving "up" the modes seems to adds a bit more weight to bass notes but only a little more volume.Add A&K PA10....
Any impressions with IEM already? Problems with hiss?
Closed. The SS3602s fit in the op-amp enclosure without any problems. As I said, you just need to trim a couple of the legs on the underside of one op-amp for them to fit properly. As the enclosure is on the underside of the XD-05 PRO, I'm not sure it would be practical to leave it open. I guess you could (maybe) and fit something crazy like the SS2590s or SIL 994s, using DIP8 extenders. I'm not a fan of open heart surgery on DAC/amps though.While using sparkos could you close the enclosure or have to use it with lid open?
I was thinking that you could put the xd05 pro on its side and then try to play around with some big opamps and make some 3d printer stand for example, but that's more in the days of immense boredomClosed. The SS3602s fit in the op-amp enclosure without any problems. As I said, you just need to trim a couple of the legs on the underside of one op-amp for them to fit properly. As the enclosure is on the underside of the XD-05 PRO, I'm not sure it would be practical to leave it open. I guess you could (maybe) and fit something crazy like the SS2590s or SIL 994s, using DIP8 extenders. I'm not a fan of open heart surgery on DAC/amps though.
I guess you could use something like the Burson Cool Stand - https://www.bursonaudio.com/shop/cool-stand/ - if you really wanted to sit the XD-05 PRO on its side.I was thinking that you could put the xd05 pro on its side and then try to play around with some big opamps and make some 3d printer stand for example, but that's more in the days of immense boredom
Can you share some initial impressions between burson and sparkos in use in xd05 pro?
Who knows what is "AES in" port? which device you can pair with it?
You right, some dac use it next to spdif oraz rca/coaxcial, usually it's full size 3-pin XLR, in xd05 pro it's 3-pin mini xlr. Only device I know of that also uses 3-pin mini xlr is xduoo x10t II (btw do any one of you know about any other similar device to x10t that could be digital transposrt wit aes other than x10t?).
Interesting, thank you. And I am looking forward to more impressions especially soundwise in comparison to the AK PA10I've tried the XD-05 PRO with ThieAudio V16 and Kinera Loki. Unfortunately, my Storm is back in Singapore atm. V16 is very, very sensitive and I have heard no hiss whatsoever. The XD-05 PRO has three power modes - Eco, Normal and Turbo. Both my IEMs can be driven in any of the three modes without issue. Moving "up" the modes seems to adds a bit more weight to bass notes but only a little more volume.
I have an XD-05 BAL and A&K PA10 to compare, although the latter is not a direct competitor. I've also been doing some testing against my iBasso DX300 and HiBy RS6, both of which have been modded by NPAudio. Lots to write about!
DDCs such as the Quloos QU02 and Singxer SU-6 have AES outputs. xDuoo seems to like offering that as an input - both on the XD-05 PRO and BAL/BAL2. I have never used it and can't really see the point on a portable device. I'm sure those more knowledgeable than I could explain the benefits!You right, some dac use it next to spdif oraz rca/coaxcial, usually it's full size 3-pin XLR, in xd05 pro it's 3-pin mini xlr. Only device I know of that also uses 3-pin mini xlr is xduoo x10t II (btw do any one of you know about any other similar device to x10t that could be digital transposrt wit aes other than x10t?).
The PA10 is "just" an amp so what sort of comparison are you after? Are you after the XD-05 PRO as a DAC/amp vs using the PA10 as the amp in line out mode? Or are you looking for a comparison of the XD-05 PRO as a DAC/amp vs another DAC with the PA10 as the amp? Or even both? I can offer all the above but it might take a while to compose my views!Interesting, thank you. And I am looking forward to more impressions especially soundwise in comparison to the AK PA10
