Unfortunately I dun have Windows where I reside now. Perhaps you can swap OTG cable to troubleshoot? I'm using my LG Android smartphones through DDhifi OTG cable connected to it with no disruption during track change.Can you please try Tidal in Windows? Also USB-C connection to Android phone? Sometimes I hear this trange noise in one headphone, sometimes in another, sometimes in both. It is irritating.
Is mine unit faulty? AFF. Second buy from Xduoo, problems again. QC not good enough...
Btw, nothing is superior to OPM401SE, it is cheaper than Burson and just the best in world. This korean guy is killing it.
It comes with all kinds of adapters allowing connection of everything to everything. I wanted to sell mine before buying Xduoo, but now.. I think I will stick with it.
xDuoo XD05 Balanced
- Thread starter arrakian
- Mar 20, 2013
I just noticed I could stick 5 ifi digital enhancers into this Dac amp
Yeah, you can chain them to your heart's content
Anyway, the ifi ipurifier3 does not comes in USB C type, does it?
It doesn't, but there are adapters
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Hello,Case are out for grab in tabao!
Where is it possible to find these cases ?
I got mine from Lazada Online. Affiliated with Tabao.Hello,
Thanks ! But they don't seem to ship outside Malaysia...
Guess so, hope you can get from Aliexpress when it's on for sale.Thanks ! But they don't seem to ship outside Malaysia...
Case just in!
It looks fine !
I hope Aliexpress will sold it...
Hope for you too . Really like the color I picked, matches the OLED screen ( yellowish orange) and contrast with the red volume knob.It looks fine !
Had to return my XDuoo Basic due to a faulty volume pot and decided to upgrade to the Balanced.
Anyone have any experience with this amp and the Sundaras?
Also, only recently ordered and received a singled-ended Audiophile Ninja cable, which is awesome by the way, but now I will have to run the Balanced in SE mode. I don't expect there would be too much of a difference with the Sundaras, but still interested in feedback regarding the benefits of the balanced out as opposed to the SE.
Im glad to help you but both my Sundara and Xduoo Balanced are in different locations. According to spec on the xDuoo Bal, it will not be a different between 6.35mm and 4.4mm socket. It will make much different in opamps replacement though.Had to return my XDuoo Basic due to a faulty volume pot and decided to upgrade to the Balanced.
Well, coming from the Basic, I actually have 2 different op-amps. Do you know if there is any issue mixing them in the Balanced since it requires 2 op-amps?Im glad to help you but both my Sundara and Xduoo Balanced are in different locations. According to spec on the xDuoo Bal, it will not be a different between 6.35mm and 4.4mm socket. It will make much different in opamps replacement though.
Are they Basic using single or dual opamps? The bal requires dual opamps.Well, coming from the Basic, I actually have 2 different op-amps. Do you know if there is any issue mixing them in the Balanced since it requires 2 op-amps?
One dual.Are they Basic using single or dual opamps? The bal requires dual opamps.
You need 2x dual opamps pieces in Xduoo Bal.One dual.
