So, are both you of saying that in order to hook it up to my PC, I need to dedicate two USB ports on it?? One for constant charging, and one for the data?
XDuoo XD-05 Portable Dac/Amp Introduction - Impressions
- Thread starter H20Fidelity
- Tags
- xduoo
Holypal
- Mar 1, 2016
Charge it. And then connect it to pc usb port. No need constant charging.
erictioh
- Nov 20, 2013
does your smart phone need to connect to usb cable to power up?So, are both you of saying that in order to hook it up to my PC, I need to dedicate two USB ports on it?? One for constant charging, and one for the data?
this thing works likee a phone it has internal battery.
what is your problem now ? turned on and nothing on lcd ? or powered up but pc cant detect
So two USB ports for this thing then, if you want to use it as a permanent PC sound source. Damn.
Good thing this was cheap.
This is not uncommon, the iFi Micro DSD has a similar solution as have LH Labs Geek Out V2+(albeit micro USB). There's also a good explanation for it as some designers doesn't like to mix power and audio due to possible interference.
I'd suggest you read up a bit before your next purchase so that you get something that suits your needs better.
You can always sell it and pick up something better for you.
i report from the op-amp thread my humble opinion of burson v5i
finally arrived the burson v5i. installed and tried.
well......i was, in the past, a set in the "high-end"guy. today, i´m more quiet and racional(my wallet sais thank you)
So, apart jokes, the meaning is that today i have an entry level system but i really like it.
when i ordered the v5i, i do not expect great things; probably a slight improvement but considering the price of the v5i, why not?????
I state that i don´t believe in technological miracles, so i say that the v5i isn´t a miracle or a giant killer but a really good product considering the Q/P realtionship.
The sound signature of my amplifier is the same but in first place the imagine is better and more focused and now i have a tight bass.
it´s a refinement of good performance of my amplifier. but more important for me is the gain. i use an oppo pm-3, so the gain is the lower.
but, so even I could not lift much the volume. now the volume is more progressive.
really satisfied
Just a last consideration about the installationa: you need to move the capacitors near and you need to push very well and at the bottom the v5i, otherwise it´s impossible put away the board in the case
really satisfied
neog007
- May 3, 2016
thanks for sharing your thoughts @alota. i'm quite happy with the burson too. Expexting more opinions of new people that got this oamp
De nada compañero
karis
- Oct 5, 2016
I just received my xd-05 and Im wondering if it is broken or not. Can someone tell me how do you know if charging is finished? Does it keep charging all the time if display is on? I assume the small red led next to charging port means charging but what are the differences of that blinking or staying solid red?
I have not tried that with my mobile with with my ubuntu laptop it worked out of the box with spotify.
In my experience it's a little bug.
If you put the charger with amplifier off, the led is fixed. If you put the charger with amplifier on and after you turn off the led blinks and when the charge is complete, the led change to fixed.
Sorry for my english, i hope that you understand.
funnytortoise
- Sep 16, 2016
Hi guys,
just wanna ask if it is possible to use the xd-05 just as a DAC without the amp? If it is possible, how do I do that?
Thanks for the help.
Hi guys,
It's possible, if you use it as a digital DAC, the Line in in the back turns into Line Out. Just don't connect to the front HO cos that's the amp bit.
funnytortoise
- Sep 16, 2016
Hey thanks a lot for the reply RedTwilight! I got it. Cheers!
apaar123
- Sep 10, 2016
should i buy this or a fiio amp/dac?
Total: 20 (members: 5, guests: 15)
