Of course. But don't expect a day/night sound improvement with this. Just a little bit better. The question is: will it be better enough to justify the 50 Eur this mod cost? will see ...
i know i know. for this reason i´m interested
I can hear some roll off in the upper treble region.
Just curiosity: did anyone here play a dxd file with this amp? I think is the maximum resolution format xd-05 admits. Is there much better than dsd or flac in sound terms? I tried to find a free dxd file to play on the web with no success..
Some toxic substances here... Photo courtesy of a friend in Japan.
DIP8 tube amps....
XD-05 isn't a multi-bit DAC, so you are listening to DSD format anyways. DXD is a high resolution, high sampling rate PCM format (352K/24bit). DXD is converted to DSD in real-time when being played.
There are measurably more treble roll-off in filters 2 & 4 compared to filters 1 & 3.
Might be worth trying out all 4if you haven't yet
I find the first part of this statement a little confusing.
Are you trying to point out that the Delta-Sigma DAC used is 1 bit, and DSD's are also 1 bit?
However, I don't quite follow why this means that it is that you are always listening to DSD format
Is this an analogy to explain how a DS DAC works? or do you actually mean that everything is converted to DSD internally before being fed to the DAC?
I've been trying to decide between this and the TEAC HA-P50, which I am currently auditioning. The sound and power of the TEAC are to my liking, but I notice a quirk on Android that bothers me. If you attach an Android phone to the USB A port the DAC charges your phone, which decreases the run-time of the DAC. Conversely, if you attach the same phone to the USB Micro port (via OTG) the phone charges the DAC. Technically, this is an issue with Android and not the DAC (this behavior is not exhibited on iOS). Some devices, like the JDS Labs C5D, have a switch to disable this. On that device the USB port is used for data or charging, but not both. Does anyone know how the XD-05 behaves in this regard? All I want is for the phone and the DAC to run independently on their own power. I would have thought that this would be easy but, at least on Android, it appears not.
XD-05 has a separate charging port. Its data port does not draw power from phone. And I don't think XD-05 can charge cellphones, at least not that I'm aware of.
