funkymartyn
How about the Cowon plenum D at about £200... ?
Slater..once again thanks for your input I will look out for a smaller charger.. Also gonna keep my eye out in the future for another player, buy a different brand. One that as much better battery life, and sounds good, probably better warranty, could still do with 2 slots, but one with good internal sd is ok...don't really need balanced, or bluetooth, ...more research needed...
A couple of years ago I picked up the Onkyo DP-S1 (basically the same thing as the Pioneer XDP-30R) which also has twin MicroSD card slots when it dropped under $200, and it has a color touch screen (as well as some physical controls) and a bunch of other nice features like BlueTooth, WiFi, 2.5mm TRRS balanced output (as well as regular 3.5mm), etc. I used it alongside my XDuoo X3 for a while, but these days I use the Onkyo a lot more. There were a number of over-the-air firmware updates (the Onkyo would just let me know when a new firmware was out, and let me apply it with a tap) that really improved the performance of the Onkyo, especially with music indexing (I have two full 200GB MicroSD cards in it) and album art while I've had it. Only real downside to the Onkyo is I see no simple way to replace the battery, so when the battery dies, no idea if I'll have a brick or not (that would make me sad). What I wouldn't give for a DAP with all the Onkyo features but an easily replaceable lithium ion or lithium polymer battery!
Quick question, , a friend is doing some 64gb cards for me with the flac, or mp3 320 size , with all artwork, Inc. Booklets etc , meant really for the pc..... But if I loads the cards into my player. ..will it be OK, and still work, but only see and play the cd name, title, etc.....But having the artwork on and extra stuff won't cause trouble ???
I like Picard. I only discovered it last year so I'm probably not using it correctly yet. It has one 'fault' that annoys me greatly, at least when I use it as it comes, perhaps there are settings/tweaks that will stop it doing it. It often identifies a track as belonging to a different album to the one I have, so gives it a different track number and artwork. E.g. I might have the original album but picard matches a track with a "best of" album or some other compilation. That screws up my track data and I have to go looking on wikipedia or somewhere for the original track listing and fix it with my tag and rename prog.
Otherwise, it's brilliant for turning mass track grabs from misc sources into an organised music collection. It completely gets around the old problem of not being able to rip tracks from an ipod back to a PC etc.
Cross post from another thread, i went to the mall and they didnt have the battery capacity i want. Went home and saw the polymer li-ion battery list and can find the dimensions for 2000mAh that is similar to the one inside X3.
Dang
