stellarelephant
Somebody posted at some point that Penon stocks the exact replacement battery. I'd shoot them an email.
I'll take mine apart and see if they're metal or plastic. I agree with just about everything you said about the X3. The controls are very ergonomic but the front panel etching is too prone to scratching, but typical cheap Chinese players don't generally have all-metal housings, and the sound quality is also far above the typical player. That said, the firmware is typical; basic functionality and even that with serious bugs. So, it's Rockbox combined with the above-average hardware that makes this player at all worth having.
I'm aware that Rockbox downsamples hi-res files, but it's debatable if the difference is really noticeable in a player of this grade, so I don't count that too much in the negative column for what you get for the price. The functionality of Rockbox plus this hardware for this price is hard to beat by any player currently available. It's actually quite a unique combination.
I was set on getting the X10 because the hardware of the X3 is so impressive, but after thinking about it, I will only get the X10 if Rockbox gets ported to it. I don't believe Xduoo are capable of presenting value in their firmware which is commensurate with their hardware.
@Riolist2 & @stellarelephant
Thanks for that. I originally bought it from tomtop...but I will get in touch with Penon to see what they say/if they are willing to help.
However - I did take the player apart and measure the battery ... it was sitting nicely at 3.6V which is more or less spot on for LiPo? Or does this suggest something else may have gone bad?
I guess next step would be to run it off external power via the battery terminal...but I don't have the connector on hand so that would be pretty hacky....
(Li-po uses another circuit and voltage)
tksTorx T5 I believe
I am glad that worked. What type of card are you using and have you tried to reformat it?
Well I got mine to work halfway I guess.
It wouldn't turn on no matter how I tried to reset it.
So one day I just said F-it and plugged it in to the USB on my laptop, and it turned on. Now the problem is that it only works while it's charging. So if I unplug it it shuts off completely and becomes unresponsive.
I think I'll head over to Home Depot and grab the screwdriver mentioned above, try to reset it from the inside.
