Bob A (SD)
- May 11, 2003
it's fine it supports it for playback. (one card appears as internal storage, the other as microsd1.) . I've plugged in the 64gb phone card in addition to the usual 128msd I use. i can confirm being able to play from both.
but i do get weird issues when connecting the player with two cards to the PC - says unrecognized device instead of it working with one card (and after disconnecting usb the player takes about 30 seconds to turn off but after that turns on fine). So it looks like the problem is specific to trying to connect the player to the PC with 2 cards
Thanks for the sanity check about the dual cards working properly for playback in RB. Sorry if I offended anyone when I said that if Rockbox didn't support dual SD cards it would be a deal breaker for me with the X3.
As for the formatting of larger than 32Gb cards in FAT32, a tip of the hat to EmPathWalker. I tested the Ridgeway GUIFormat.exe utiliuty with my Samsung 64Gb Class 10 card and it reformatted it from ExFat to Fat32 effortlessly.
So it would appear that I need to backup my two SiliconPower 128Gb Class 10 cards, reformat them into Fat32 from ExFat, and reinstall all my music which is a very s-l-o-w process (hours and hours) using USB2 with my Win 7 SP1 64-bit OS desktop.
