Inszy
- Jan 1, 2014
You need to download MP3Tag (free) and remove the comment tags and album/artist from the files. (its a tag problem)
Or just update firmware.
Yes, sounds like the best solution doesn't it. Though members I spoke to said the new firmware brought it's own new set of problems.
My player works well with the new firmware - no problem. I think your player from the first wave of production, she is often defective.
Hmm, actually, what I read was a post from svyr saying his unit crashed completely after installing the new firmware and he needed to return it. I think this was just a coincidence though, not a fault of firmware, so disregard the above comment about new firmware causing problems. I haven't installed the new firmware on my unit, it runs fine besides the previous tag "format error" sometimes.
Line out ready for use with high-impedance load - an external amplifier. This player does not have a line-out and it can be connected only through the headphones-out. And its internal amplifier can even break itself when connected to an amplifier with very high input impedance, as Fiio E12 or my Aune B1. Bad idea. But X2 works well with Topping NX1, I think Topping, like a cheap amplifier has a low input impedance and X2 can play with it well.
[X2]+[low impedance and high sensitivity earphones]=bad sound
[X2]+[good cable]+[Topping NX1, $40, now US$ 33.98 in the ShA, ebay]+[low impedance and high sensitivity earphones]=very good sound
PS My Dunu Titan 1 good play with the player. Impedance 16 Ohm, but big drivers and sensitivity 90dB! And very good X2+Brainwavz BH5.
IMHO, xDuoo X2 like big drivers and high impedance. If you need to use earphones with low impedance, it's good to add Topping NX1.
PPS X2+ Titan 1. This combo - a great joy for a basshead at EQ is "normal". I use setting "soft"
Só if I pair um my x2 + a good cable+ topping nx1+ a kz ed it will sound good or is it better without the amp?
Yes. And reduce noise - Topping NX1 as high resistance load, "kill" noise X2 and replace on NX1's noise - the noise weaker.
PS New firmware, may be coming soon - fix "fade in", "fade out" and troubles with APE
Sorry to reply, but by yes you mean no amp right? btw, Thanks for replying!
