Baten
- Sep 13, 2012
I also like the metal base MELZ foton tube, can be found on eBay but are a bit pricier.
Well thank you for your reply you may just save me a bunch of money in tube rolling. Sounds similar to Op amp rolling minute differences. But you're happy overall with the sound of the amp?
Well thank you for that mini review. I've read a lot of YouTube reviews and different things on the amp it seems like for the money it's pretty damn hard to beat. I got one on the way that I picked up for $230 open box. I will be putting a Alps potentiometer immediately.
I don't hear of anybody doing any mods on the inside I know it's pretty tight and things are kind of crammed in there. I'm actually thinking of changing out some of the capacitors and stuff for better quality stuff see if it makes any difference. I like to mess around with stuff, can't find anybody that's really done that.
Are you on the original tubes? They are not very good, my TA-26 with mid-price tubes is way better (and more "tubey") than with the original ones.Been messing around with the amp for 2 or 3 days don't like the sounds the sounds a little sterile it's not tubey enough sounding.
The item is for sale here in the classifieds on this website also I've listed it on eBay if anybody's interested has about 8 hours of play time on it basically it's brand new.
Not OP but Sylvanias are nice and Tung-Sol tubes do a great job too.Yeah I'm on the original tubes. The question is what tubes there are so many tubes to try and I don't want to spend $250 on tubes on a $200 amp think I'm just going to upgrade to a better amp.
I thought about rolling tubes on it but I don't think I want to go down that rabbit hole.
What tubes are you using?
I'm out of town for a few days, so can't be sure, but I believe it's a RCA on the back and a Hitachi on the front.Yeah I'm on the original tubes. The question is what tubes there are so many tubes to try and I don't want to spend $250 on tubes on a $200 amp think I'm just going to upgrade to a better amp.
I know when there's an amp out and there's not a 15 or 20 Page thread on it it's typically not a very good amp when you get a gem of an amp there's usually a pretty good following of people and a lot of activity this is a four-page thread which tells me a lot about the amp.
