xDSD Gryphon: birth of a ‘head-fi’ legend
- Thread starter iFi audio
We'll see. If they retain the micro USB ports, they can keep it
Johnfg465vd
If this post is genuine, then it comes with both the Micro & C Type ports for Data transmission. Still using the Micro for charging though. I guess they wanted it to be compatible with Poly.We'll see. If they retain the micro USB ports, they can keep it
I highly doubt it will be as versatile to use as the Gryphon. Having owned both Chord & iFi devices it would probably be hard for me to pick one clear winner over the other, both have their own sound signature and way of presenting music. I guess we'll have to wait and see how much of an improvement Mojo 2 will be over the Mojo.
Why does the Gryphon instructional manual say to use the “Lightning to USB Camera Adapter” to connect an iPhone to it? Can’t I just use a Lightning to USB-C cable to connect iPhone to Gryphon?
@iFi audio
@iFi audio
how do you like the ext with the gryphon? good pair up?Why does the Gryphon instructional manual say to use the “Lightning to USB Camera Adapter” to connect an iPhone to it? Can’t I just use a Lightning to USB-C cable to connect iPhone to Gryphon?
I don’t have the Gryphon, but I’m considering it although not sure yet.
Scubadevils
Previously known as Scuba Devils
- Nov 18, 2011
My Gryphon landed today after a long wait. Very impressed on day 1 - it sounds incredible with every IEM I've tried and is a beautiful unit. Connected to the wonderful DUNU ZEN PRO in this shot...
m3lover1
- Apr 22, 2017
Looks beautiful. That cable looks sick too
mwhals
- Jul 26, 2015
The iPhone does not output audio signals from the charging port. The camera adapter has hardware to bypass the iPhone dac so audio can be passed through the charging port to an external dac. It basically allows the lightning port to receive and transmit data through the lightning port.Why does the Gryphon instructional manual say to use the “Lightning to USB Camera Adapter” to connect an iPhone to it? Can’t I just use a Lightning to USB-C cable to connect iPhone to Gryphon?
@iFi audio
This is not an issue with dongle dac-amps though AFAIK. Lotoo Paw S1/2 and Cayin RU6 don’t need the Apple Lightning to USB Camera Adapter for instance.
So you need to used the CCK for iPhone? That's odd and not at all what I was hoping for. I have several other DAC/amps and none of them requires it as long as I have the right cable. Can a fellow iPhone user who has Gryphon confirm? I've been considering a purchase, but that would likely make it a "no".
According to the iFi video below for the Gryphon @ 1:24, it doesn't mention anything about needing the Apple "Lightning to USB Camera Adapter" to connect iPhone/iPad to Gryphon's USB-C input.
However, the user manual says that the Lightning to USB Camera Adapter is needed:
So, this is confusing. @iFi audio @Sebastien Chiu, what's the way to connect an iPhone to Gryphon's USB port? I was hoping to avoid having to use the camera adapter, definitely a deal breaker if that's actually the case.
named name
You do not NEED the Apple CCK to connect the Gryphon to your iPhone. You can use alternatives, I personally use a DD HiFi lightning to USB C cable and it works just fine connecting to my now archaic iPhone X.So you need to used the CCK for iPhone? That's odd and not at all what I was hoping for. I have several other DAC/amps and none of them requires it as long as I have the right cable. Can a fellow iPhone user who has Gryphon confirm? I've been considering a purchase, but that would likely make it a "no".
However I believe that iFi are just covering their asses in case Apple decides to update and break something in a future iOS update.
There's a Lightning to USB-C cable included in the box. I don't use an iPhone but it would be strange if that cable doesn't work...
Scubadevils
- Nov 18, 2011
I'm finding the 4.4mm connection very stiff with all of my IEMs - I have to push quite firmly to make the connection, likewise to unplug. Anyone else have this? I've not experienced before, hope not something that could damage the unit or jack.
Total: 9 (members: 0, guests: 9)
