galaxysound25
- May 28, 2022
Thank you for sharing your experience. Its great that Gryphon would pair well with Arya. Actually I'm going to use Gryphon mostly with Mest Indigo and Mest Mk2 for portable or travelling purpose. Arya I'll use at home only. I'm planning to buy a good desktop DAC after few months specially to pair with Arya but till then I'll use Gryphon only with Arya as well. So it is good to know that Gryphon doesn't hiss with any of the Arya, Indigo or Mk2; or otherwise it is very less, not noticeable hiss via 4.4mm. So I'm planning to go ahead with Gryphon soon. Thank you.Deffinately no hissing, just a little faint noise if you listen carefully, but that is with extreme low latency like the shure se846 around 9/10 ohm. But the moment you listen music it is gone. More noticable on the 4.4 (because if the higher power). But the 4.4 does sound better than the 3.5 port. In extreme cases you could use the iematch, but I don’t even use it on the shure se846. The gryphon is a amazing device. Love the small form factor.
I do have to say though I tried the arya stealth on the gryphon, and yes it definately sounded great, seriously great! Don’t let anyone let you tell otherwise.
But connected to for example to the ifi micro idsd signature you could hear a little bit more of control on the arya as a whole (but! Not night and day, just a little better) Just little bit smoother as a whole
