Hi to all. I recently got Gryphon. I am a bit surprised by the fact that the balanced output (front) is ONLY marginally louder than the single ended one. I did measure the SPL via an SPL meter - not very scientific but fairly indicative I guess. In order to achieve around 80db SPL in single ended I have the volume level to around 85, while in balanced output around 80-82. Is this to be expected?
Based on just assessing the volume by ear it has been my experience that the 4.4mm is about 10 less on the volume reading than the 3.5mm.
Given the uncertainty of measuring and/or assessing the volume by ear, the different behavior of different IEM or headphones I would say that you are in the same ballpark.
Unlikely there is a problem.
Volume reading seem to be an odd thing with the Gryphon. Out of the main 100 range the lowest 30 seems essentially unusable and the last 15 or so ramps up quite quickly. This creates a sense that we are always running the Gryphon pretty hard when that is probably not technically true.
If the volume range was more usable at the lower end and ramped up more gently across the whole range you would see quite different volume numbers in different circumstances and it would probably make more sense.
First world problems.
