@Lightspeed12 I would choose the Gryphon if I were to only use IEMs for the following reasons:
- it has 3.5mm; I mostly use the 3.5mm with IEMs as all I have are sensitive;
- there is plenty of power on the Gryphon, even on the 3.5mm;
- has Bluetooth, which for portability is essential in my opinion;
- has USB-C connectors which is a big plus compared to the non-typical male USB-A used on the Signature (which from what I have read only works with supplied cable);
- the Gryphon also has a LINE IN (both 3.4mm and 4.4mm), meaning you can use it as a headphone amplifier only; I use it this way with DAPs or other older devices.
Note that the Signature does have 4.4mm balanced, but lacks 3.5mm single ended (which is by far the most common connector).
You will need a 6.3mm to 3.5mm adapter, which will make the overall length a bit larger and also more risk of breaking the 3.5 if used in a pocket.
In my view, the Signature is more suitable for desktop use, as
- you have the RCA connectors which can be connected to an external power amplifier;
- you have significantly more power, which for over-ear headphones (especially high impedance and planar magnetics) is a big plus;
- you have the 6.3mm jack, which will work with many studio-type headphones, which already have that as standard;
- given it has 2 x DAC chips, I would expect it to sound better, as
@JoshG1217 has already mentioned;
