Please do a comparison vs Dethonray Honey,
Thank you,
Thank you,
I'm wondering if anyone has compared to their hip dac. Is it a noticeable upgrade in sound?
Stay updated on iFi audio at their sponsor profile on Head-Fi.
My Gryphon will get warm whenever I use it. It only becomes hot when using it while charging.Does anyone’s Gryphon run hot with even easy to drive headphones like m50x? I have the xCAN that never gets warm or hot, but the Gryphon seems to get very warm and sometimes hot. I’m not charging at the same time; just running off battery. Maybe I need to update the firmware. I’ve been running it with whatever it shipped with. I haven’t wanted to change anything because it sounds so good
I think there is an iFi-Gaia app on the App StoreWhen trying to update the Bluetooth driver for IOS do I undertake the update via the phone or PC?
Via phone. You’ll have to download using the Gaia app then save the files to your files app to be able to upload to Gryphon.When trying to update the Bluetooth driver for IOS do I undertake the update via the phone or PC?
just a thought,, if any plans to add in the setting "gain selection" mode digitally (if possible tho), so in stead getting red LED on the Gryphon which is too loud, should only at Green and Yellow but with more thrust @iFi audio
Anyone experiencing a pop when turning on XBass?
With last firmware no, it's just a light "click".Anyone experiencing a pop when turning on XBass?
You first!Please do a comparison vs Dethonray Honey,
Thank you,
