MarkParity
I'll go if you have room in your suitcase for me.Folks, is anyone here going to Munich by any chance? If so, please visit MOC's atrium 4.1, room E109 with WOD audio as that's where we'll be
I use this one.
https://www.amazon.co.uk/gp/product/B091DWHVHS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
When plugged into the QC port I get a 1.8A charge @ 5.2V using the supplied USB A to USB C cable.
I didn't say it was. 5v @ 1.8A = 9 Watts which is about the limit for the Gryphon.That's not Quick Charging. I believe the Gryphon only supports BC 1.2...
Its just that the charger that I linked to allows the highest wattage charge from the QC port. The others only allow a 0.5A charge which I use for when charging speed is unimportant.
Welcome to my world. I flagged this as an issue months ago. What needs to happen is for iFi to give us the option to disable AptX Adaptive in firmware. Failing that, this 'glitch' with the V60 (and a few other phone models) won't let you use LDAC with Gryphon. Interesting you managed to use LDAC with GO blu? I have the same issue there.
@Sebastien Chiu @iFi audio
Are there any alternatives for gryphon? Like something similar size, power and BT? Not just IFI i mean?
Is anyone using the iFi Gryphon with an iPhone (streaming Apple Music)?
How do you find the connection and quality over Bluetooth? Still worth it to get the Gryphon while knowing that iPhones only have the AAC codec?
The dealer gives me a brand new unit as a replacement for the "ill-fated" Gryphon. Hope this one will fare better than the last. Please wish me luck
xDuoo XD-05 BALAre there any alternatives for gryphon? Like something similar size, power and BT? Not just IFI i mean?
FiiO is also working on Q7 DAC/AMP which is expected to be released in October. They also announced they considering a portable Q5 Pro for end of the year launch which I believe is direct competitor to both xDSD and XD-05.xDuoo XD-05 BAL
I used my previous Gryphon for about 4 months before it "went back to Egypt", and I love it. The replacement seems to have a stiffer volume knob. The only thing I am not in love with the Gryphon is the battery indicator. Sometimes it suddenly turns off when there are about 2-3 dots on the battery icon and the lack of low battery warning beside the onscreen text.Let us know what you think after you get some time with it!
Indeed the xDuoo XD-05 BAL seems to be close to the Gryphon from many points of view (although not 1:1 identical obviously):
- it has similar output power (1W@32ohm); I say "similar" because real figures will be different than spec;
Of course we need to keep in mind real figures will vary and depend on many factors like how much of an inductive component the headphone drivers have, etc.
- has USB-C, has a screen (although nowehere near as nice as Gryphon), has 4.4mm jack;
- has Bluetooth with all the codecs;
Stricly from a bang-per-buck point of view, the xDuoo seems a better option in my opinion as:
- it has significantly lower THD+N;
- replaceable op-amps; not a huge deal, but it's something that I personally like as a concept;
- has a 6.3mm jack (but does not have 3.5mm); here I kind of prefer the 3.5mm;
- on paper it seems to have better battery autonomy (can't find a spec for Gryphon, but in my experience 4-5 hours at medium to loud volumes);
- seems to have more digital filters (I see FILTER8 on the presentation picture, so I assume at least 8);
- it's cheaper than the Gryphon by a pretty significant margin;
Advantages of Gryphon:
- XBass and XSpace features;
- 3.5mm jack;
- extremely good looking;
- has MQA decoding; for me it's not a huge deal, I did not buy it for this reason, but for others it might;
- has IEMatch, which can be sometimes useful, although I would have preffered to simply have a better DAC with lower noise floor;
I do have the Fiio Q5s and compared to Gryphon it's very anemic in terms of output power. It's one of the big reasons I upgraded to Gryphon.
The Fiio also does not have a screen and mine is the older version with microUSB, not USB-C. However, I do like the Fiio Control app, which has
EQ built in. This is something that's missing on the Gryphon, I would have liked to see it both in Windows driver and mobile app.
Looking forward to the Q7 and possibly the Q5 Pro if they make one. It's always good to see more such products.
Of course, from an audiophile point of view, it's tempting to have all of those devices, not settle on one of them.
I am happy with my Gryphon overall !
I do hope the volume in dB and adjustable screen brightness when OFF will be reintroduced in future firmware iterations, this is something I really miss.
ownside being bluetooth is so bad, it's basically unsuable on-the-g
Depends if you are asking about audio performance or features.How does the GO Bar position against the Gryphon?
Usually the answer to this question from Ifi is that audio performance scales with price so Gryphon will sound better and does have a lot more features too. The Go Bar wins on portability though.
Comparing this two is a little like comparing a Supercar to an SUV perhaps.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I really like Gryphon too, especially that iFi read this forum and react to comments and suggestions, and comes out with solutions fast.
Respect @Sebastien Chiu this is how support should look like ...
Comparing these two is a little like comparing a Supercar to an SUV perhaps.
