After several hours listening Tidal with my Gryphon by the balanced output, my left channel is now almost mute
Firmware 1.43 - > is it the problem?
My IEM are working, so the problem is the Gryphon. On 3.5 output there's no problem.
Is there anything I can do? Factory reset could help?
@iFi audio I need help
Thank you!
Edit: I updated the firmware to 1.45, but left channel is still mute on balanced output
Same problem after a factory reset
Edit 2: if can help, it happened when I was enabling xbass/xspace (I don't remember which one, but I was pressing the switch button).
Also the 4.4 line out is mute on left channel.
Anything change if I enable IEMatch/xbass/xspace with xbass in the three different features bass/presence/both
