Folks, our
xDSD Gryphon XMOS firmware V1.43 is now available with release notes below (this is NOT Bluetooth firmware):
1) Added maximum Volume Limiter option (60%, 80%, 95%, OFF). Default is OFF with maximum volume set to 100%.
Go to Settings (hold down GEAR button for 3 seconds), turn VOLUME knob to Volume Limiter, press VOLUME button to select, then turn VOLUME knob to select a percentage. Press GEAR button to exit settings.
To use: turn VOLUME down to Mute (minimum volume), short press VOLUME button once to unmute.
- When Volume Limiter is set at 60%, the maximum volume is 66db. To use, set to Mute, volume jumps to 49db after a short press on the VOLUME button.
- When Volume Limiter is set at 80%, the maximum volume is 86db. To use, set to Mute, volume jumps to 64db after a short press on the VOLUME button.
- When Volume Limiter is set to 95%, the maximum volume is 100db. To use, set to Mute, volume jumps to 75db after a short press on the VOLUME button.
- When Volume Limiter is set to OFF, the maximum volume is 106db. To use, set to Mute, volume jumps to 79db after a short press on the VOLUME button.
2) Added volume synchronization option in Settings.
3) Added volume soft ramp option in Settings.
4) Added volume lock function. To lock/unlock volume control, short press VOLUME button and XSpace/XBass button simultaneously.
When volume control is locked, a small lock icon appears on the screen.
5) Fine tuned volume stepping. Volume level below 100: low gain. Volume level above Turbo 101+: high gain.
6) Updated volume LED light indicator: blue: 1 ~ 21, purple: 22 ~ 41, magenta: 42 ~ 61, green: 62 ~ 79, yellow: 80 ~ 97, red: 98 ~ 106
7) Optimized battery full charge voltage detection. Charging time is about 2.5 hours with a high-power charger.
8) Updated menu display.
9) Updated Screen Brightness Setting as follows:
- High: Screen is displayed in high brightness. If no key press after 10 minutes, display will be reduced to low brightness. Press any key to restore high brightness display.
- Low: Screen is always displayed in low brightness.
- Off: Screen is displayed in low brightness, if no key press after 10 seconds, screen will be turned off. Press any key to restore low brightness display.
Please feel free to try it out, thanks!
