chupacabra314
- Oct 8, 2014
Is it possible to have more lines of text in the playlist/folder views by decreasing the font size or is the line size fixed?
Just got my Fiio X1 a couple of days ago, and I'm highly impressed with it so far. If anyone is interested I've created a custom firmware ...
I've kept the design pretty simple, as the default icons and fonts are okay in my opinion. If you'd like to try it you can download it from one of the links below ...
Thanks TCD1975 great theme! currently on my X1, how can I edit the highlighted color in this theme?
do you guys have customized boot animation?
Do you mean change the red color to some other color?
When did you download and install the firmware? When I first posted the firmware link, I'd only updated the first theme (red), but I've amended the firmware now so that all 6 themes use my design but in different colors ...
- Theme 1 - red
- Theme 2 - orange
- Theme 3 - green
- Theme 4 - blue
- Theme 5 - purple
- Theme 6 - magenta
If you downloaded and installed the firmware before I updated the link, you'll need to download and install the firmware again. Otherwise, just go to system settings > theme and change it to whichever color you prefer.
Yes, maybe it´s my fault I didn´t explained the question well, How do you edit the firmware to make for example the same theme but with another colours in the highlighted area?
You can change the highlighted areas in
Tom
