Dalamar
- Jul 4, 2009
Aside from measurements, there is no non-human way of testing, and the alternative: subjective tests, is just useless.
Measurements will result in the output sounding like the input, and if it sounds bad, well, maybe you should blame the digital recording. Or the INAUDIBLE JITTER!!1
I recommend blind tests because measurements are often too small to be audibly different, and if you can't tell (without the placebo) why spend more? If you think the worse item is better... or can't tell... why buy the better one?
