No, because I'm not an electrical engineer, and I'm honestly not interested in learning all the science behind headphones and amplifiers.
Are you just here to feel special about your technical knowledge, or are you actually going to tell us which amp you're using?
(surely, I can't be the only one who feels like their bashing their head against a wall here?.. I think I've asked coolhand 3 times now in various ways - WHAT AMP ARE YOU USING?... I think i'm being trolled)
Absolutely fair enough GREQ, not everybody shares my thirst for knowledge in subjects of interest to them, and not learning all the science behind headphones and amplifiers shouldn't get in the way of musical enjoyment.
I don't 'feel special' about my technical knowledge or more often lack of it... which is why I have made a point to read & mostly quote from others and link to their pages in my responses, people whom I greatly respect for having shared their time & valuable information by making it freely available on the internet to be accessed by curious others.
I like to discuss stuff with like minded people, that's how figure most people also naturally interact in life outside of online forums, expanding their consciousness and enjoying life
Previously I made it clear that there are no miracles, no magic amps or headphones for that matter... in fact absolutely everything in life is the result of an interaction.
The notes I posted above clearly inform an even vaguely interested reader of several things most pertinent to this discussion (and so lets see if I can fit this in less than 500 words
"Higher impedance headphones (150Ω to 600Ω), also depending on the rise of the impedance in certain areas again may sound better on higher output resistance amps"
"High impedance headphones are designed to be used with higher voltage amplifiers"
"High voltage amps can drive high and low impedance headphones with a series resistor.."
"The T1 was
definitely designed for a higher Ohmic amp, The HD800 also benefits and this explains also why some find the HD800 lacking in lows and others have no complaints.
In many regards the HD540 is not entirely dissimilar to the HD800 and so the above is a highly relevant observation....
If I am to presume that you have an even slight interest in making the most of these headphones, I may also take the liberty to presume that you are aware that they are of a higher impedance type and are 300 or 600 ohm... and thus having read the above you may begin to understand that in order to sound their potential
best, the HD540
requires both:
-An amp which can swing a
lot of voltage
-An amp with a relatively
high output resistance
The vast majority of specific 'headphone amps' on the market regardless of cost or complexity do not have both of these characteristics together, in fact it's extremely rare.
One reason why is because the vast majority of headphones on the market are far lower impedance types and the other reason goes hand in hand with these lower impedance types, that is high output resistance amps will make most low impedance headphones sound lousy, with very pronounced deviations in acoustic response.... for instance boomy bass and peaky highs.
It's also a generalised attitude by amplifer designers that the best sounding amps have the lowest output resistance, and indeed this holds true for a large majority of cases,
but not all.
The HD540 is a case in point, (although there are numerous others such as the T1 and the AKG701 etc...)
Actually the 600 ohm HD540 is the better sounding version for reasons which I wont elaborate upon here, and it further exemplifies the point.
SO THEN, EXACTLY WHAT PHARKING AMP IS BEST FOR THEM ALREADY ????????????????????????????????
