geom_tol
- Jul 29, 2001
I was the other volunteer for the show, it was fun unpacking the stuff and handling all the gear. *drool*
During the tour Tyll gets the title "Hardest working man in the headphone business", he was sweating pretty good after we had everything unpacked, it was a fairly hot/humid afternoon in DC.
For me the Blockhead ruled supreme in the high end case.
The Orpheus (and the other tubed amps to a lesser extent) does not handle dynamic/punchy/fast music well. You loose the feel of the music. It sounds great, no doubt about it, but it is missing the energy, the speed.
For vocals and music with few instruments/players the Oprheus and other tubed amp are awesome!!! They sound soooo good.
In the headphone case the headphones were driven by maxed out home amps and a Marantz cd67se.
The hd600 and rs1 sounded suprisingly similar in this setup. My current can the k501 did well in comparison, it's sound was different, not worse, just different.
The four best cans were, hd600, rs1, k501, dt931. No surprises.
In the cable comparison setup I draw no conclusions. I think the test is flawed, because of the varying age of the hd600's used.
The hd600 with stock cable seems brand new, the pads are very hard, so the drivers are held away from your ears by the pads.
The hd600's used for the clou and cardas cable have very soft pads, so the drivers are alot closer to your ears.
This changes the sound dramatically, so I'm not saying anything about the cables. Except that the Clou cable is very heavy and thick, I did not like the feel of it.
In the case with misc. amps I really liked the ASL MG Head OTL, and also the McCormack amp. The MG Head is especially impressive considering what it costs.
I listened to a Corda HA1, it has a 'brighter' or 'lighter' sound than most of the other amps there. Very good amp for the money.
I listened to the RA1. It was as bad there as I knew it would be (btw. I own this amp, I have listened to it alot). Tyll also expressed his 'dislike' of this amp and proceeded to open one up to show the insides.
I also let Tyll listen to my newly built meta42 amp. We compared it to a Headroom Cosmic. the source was a panasonic portable cd.
Tyll liked the sound alot, he thought the Cosmic had better bass and highs. I agree with the Cosmics better highs, but I thought the meta42 had better bass. The sound was very similar, the amps simply dissapear when listening.
I was very happy with this. the Headroom amps are extremely well built and engineered. They had a display showing the insides of all the Headroom amps. Amazing stuff. All connections are soldered onto the board.
My meta42 has a lot of wiring, and some doubtful soldering, as well as only about 3 hours of running time. Tonight I will finally have a chance to do some long listening to it with a good source.
