I just sent this to Jack:
"Whilst I accept what you have said about the compatibility of the WA6 SE maxxed design with the 274B tube (I had a really big flash and lots of sparks falling tonight), there are a number of people who have modified their own WA6 amps because they believe that the first capacitor is too high a value at 150uf, where Sophia Electric state that is should be no more than 4uf. I know that you use a choke (inductor) in the WA6 SE design, but again the thoughts being expressed to me are that if the choke is not at around 20 henrys then again it is not sufficient to stop the current in-rush to the tube, which causes the flashing and sparking.
Would you share with me the values of the first capacitor (I believe that it is a 150uf Blackgate) and the choke that you use in the WA6 SE with premium parts upgrade that I have? If I wanted the amp to be modified to have the first capacitor changed to 4uf (in line with Sophia's recommendation), would you be able to do that if I send the amp back to you for modification (unless you have any associates in the UK that you would be happy to undertake the modification). Am I right in assuming that the rest of the amp, and its ability to drive low or high impedance headphones, would not be affected?
Please don't take this as any criticism on my part of your knowledge or expertise. I just want to be able to use the Sophia Electric Princess 274B tube without the flashing or sparking, which must be shortening the tube life and performance, and the best way to achieve that would be to be in line with their recommendations."
Let's hope for a response with some detailed information.
