Gradofan2
- Jul 2, 2005
Based on the foregoing "meadering" and speculation... we can draw the following conclusions:
1. Both the WA6 and the WA6 SE use a CAP INPUT SUPPLY - not a choke input supply.
2. The PSU filter cap, must not be of too great a value, or must have a resistor after the inductor too avoid stressing the 274B tube.
3. The WA6 and WA6 SE both use a PSU filter cap, which is too large to safely allow the use of 274B tubes, without stressing them and shortening their life... and... must either have the value of the PSU filter cap reduced, or a resistor added after the inductor, to allow safe use of the 274B tube.
4. That is the case for both the WA6 and WA6 SE.
5. One person has reduced the size of the PSU filter cap value to resolve this issue... and... it is a better solution than inserting a resistor after the inductor.
6. Reducing the value of the PSU filter cap, or adding a resistor after the inductor, can reduce the current output so much that it will reduce the amps ability to drive low impedance phones well - so you must be careful.
7. This is only an issue when using the 274B tube, and is not an issue with other rectifier tubes such as the 5U4G, 5AR4, GZ30, GZ32, GZ37.
So, you don't have to worry, if you don't use the 274B - its best not to use a 274B tube, unless you make these modifications.
I'll forward this to Jack and adivse him to change the design of the WA6... at least for mine.
