JwangSDC
- Dec 26, 2007
So I got my WA6 SE but without a DAC I can't listen to it. But I did notice that nothing on this amp connects firmly. I spent an hour and a half screwing the PSU cable in because it never looks like it's fully connected the way it says in the instruction manual.
Also, what is up with the tubes? There's like a 2cm hole between the connectors and the top so it's very hard to see how solidly they are put it? I'm paranoid with fragile expensive things so I'm really worried. I upgraded to the teflon tube sockets for reference.
Did anyone else have the same problem? The 6EW7's are specifically the hardest to tell if they are in all the way or not. Even pressing them down maximally they are easy to shake around...
