eelton
- Feb 10, 2014
Have you changed your mind since then? Either way, thanks!
I'm very happy with the WA7. As to whether I hear any sonic difference vs. my solid state amp? I don't think so.
I have this, too. Now that you mention re-connecting, I might have seen that once or twice. But, I just tried it and no difference. Have you found any solution to this?
No, I still need to re-connect the USB cable to get all sampling options. A minor inconvenience but it always works.
This time, the re-connecting took. This will be frustrating. Seems like there should be a fix for it.
What platform are you on and OS version? Do you have third-party apps e.g. Skype, PureMusic, or DAW taking the audio devices priority? Please email us at info@wooaudio.com for additional troubleshooting.
I'll send an email, too. I had it on both Mac: Mavericks (I forget the exact version number, but the latest) and now on Yosemite (v10.10). No other audio things running that I know of.
After a ton of similar issues with Audirvana I have switched to JRiver and it seems to be much better all around. There are still little issues here and there compared to say iTunes but the sound quality is excellent and the interface is pretty decent too. It now also supports movie playback as well so if that matters to you...
Do you have better sound quality from the same audio files with JRiver vs iTunes? Trying to get my head around this.
Thanks.
HS
yes, better sound same files.
Interesting. I'm simply running iTunes and have not explored alternative music software for my Apple transports. I prefer simplicity, but I'm afraid I may be getting further and further away from it going down this audiophile rabbit hole...
HS
