sikidhart
- Aug 20, 2016
Hi!
I've been searching for wireless earbuds for running and I have tried a few of the usual recommendations at the store.
Almost all of them form a tight seal which makes a thumping sound on every step.
So far, I found that the only pair that doesn't do this is the Bose Soundsport Free.
I'm thinking of getting this but it's quite expensive, and the reviews say that the connection only goes to one earbud and the other is just a slave, so it loses conneciton from time to time.
Is there any other earbud with a similar fit to the Bose Soundsport Free?
I don't care about the sound quality, or any of the bells and whistles like microphones, or making outdoor calls, or fancy touch buttons. I just care about the fit (comfortable, doesn't fall off, no airtight seal) and the connection (doesn't have to pair quickly, just has to stay connected). Of course sweat proof is a must too.
Thanks!
Thanks!
