Aside from differences in bit rate, resolution, and file format, what you likely are likely hearing is differences in loudness compression. All the streaming services apply some normalization to the loudness. For example, Tidal and Spotify targets -14db in LUFS units. Though the compression algorithm will vary, and can have an audible difference between streaming services. Once you use more than 192 kbps rates for compressed audio, you'll actually cause more audible changes to the sound quality with compression than by bit rates or resolution differences.
