gregorio
- Feb 14, 2008
[1] When we come to these forums and dispense advice, we have no way of knowing who is reading it. There is by definition a spectrum of listeners. Therefore it makes sense for such advice to encompass the population at large. This is what I call achieving channel transparency.
[2] There is also a second reason for my recommendations: when a device fails to achieve the specs of the silicon they are using, and others can get there with little to no price premium, we need to rally around the companies that do good work. This is what I call engineering excellence.
[3] What I don't have any patience for is to say no one should care for either as Bigtop did.
1. As I see it, what you are suggesting effectively covers not only an extreme situation but a number of simultaneous extreme situations, which are necessary to achieve achieve transparency to the levels you're talking about. How many consumers are trained to the level of a Harman trained listener, how many of those also have an exceptional monitoring equipment/environment in their homes, how many of those who remain are listening to content where such levels of noise is actually achieved and how many of those routinely listen at levels higher than intended? Unless someone is specifically testing for noise levels rather than just listening for entertainment, it's possible that the number of "those" who remain is zero or if there are some, they are certainly outliers. I understand that as an equipment engineer you ideally want to cover all possible eventualities and all the above conditions certainly are possible, just very unlikely. As a content creator I typically have to deliberately ignore "those" remaining people (outliers), because catering to them is often impractical AND undesirable, as it would compromise the enjoyment for everyone else (the target audience).
2. This statement brings us right back to the question I've raised several times, which you refuse to address! I entirely agree with your statement, that with "little to no price premium" it is possible to achieve even your "all encompassing channel transparency" and that we should "rally around" the companies who achieve this "engineering excellence". BUT, what about those companies who achieve that "all encompassing channel transparency" but at vastly higher price premiums, with marketing stating/implying that such a vast price premium is required to achieve such audible transparency, should we also "rally around" these companies or should we not attempt to debunk their marketing and over-charging?
3. I don't see bigshot as saying no one should care. I've had my run-ins with bigshot in the past but he's entitled to say that for him, a DAC beyond say -80dB makes no difference and is therefore not worth caring about. At least he's thought about it, which is more than most do. It's also entirely possible that for the majority (probably even the vast majority) of consumers with their listening skills and usual consumption habits, that he's absolutely right. I prefer to cover more eventualities and feel safer quoting a figure of -100dB or so, while you want to cover all possible eventualities and quote -120dB. All three of us are entitled to these opinions here, as all three of us have justifiable reasoning for those opinions but, each of these opinions also have reasonable counter arguments (except mine of course, because I'm right and you're both wrong!)
G
