Also, if its range goes well outside of the limits of hearing, then that would suggest that it's not struggling to reproduce the frequencies that are at the very ends, in other words they're suggesting that its response curve isn't rapidly dropping at 18 kHz if the driver can actually reproduce 30 kHz. A frequency graph would be more useful than just saying 5-30,000 Hz. There's never any context of +/- x dB attached to those "specifications" either. I would pay little attention to those unless it's quoting figures that are within the 20-20,000 range. If its quoted range stops within those frequencies, then it will probably have a deficiency at that extreme that would be obvious to anybody.
It's much closer to this. You'll find a lot of fundamentals are rather low in frequency, but the harmonics of those instruments and the extremely wide range of physical and virtual, electronic instruments (additive and subtractive synthesizers, for instance) can easily drive to either end. I normally do a lot of "house keeping" along each instrument, and then each bus/group and
tend to use a sharper roll-off (24 or 48 dB/octave) at the sub-bass end and a low-pass shelf at the high end to keep the effects (reverb, stereo imaging, and now binaural work) from being twisted up with a sharp cutoff right at 20 kHz and leave the resampling and dithering to mastering processes to get it from 24 bit/48 kHz to 16 bit/44.1 kHz. When producing, even the deepest sampled instruments tend to be 24 bit/48 kHz, and the only instrument I've recorded directly is with the intent of distortion (electric guitar), so I monitor and calibrate beforehand anyway. But hey, if you're recording it, throw whatever resource capacity you can at it as you never know what tech later on can expose details you were able to capture.
There are times where in the same house keeping process you might want to make sure the overall to and bottom ends don't get a chance to bleed over into the Nyquist cutoff, but I rarely have anything go beyond 22 kHz anyway. A lot of times, depending on target format, the assumption is that the playback will likely mask the chop off at either end if using MP3 (depending on the CODEC and settings used) or some other lossy, possibly streaming format. It's partly why I tend to research as much as possible before I bother getting "HD" versions of tracks. And even then, I don't bother with anything over 24 bit/96 kHz until I can try DSD-targeted tracks (ones that were always intended to be mastered at high resolution). Mostly because I just want to hear the difference for myself.
