Originally Posted by Willakan /img/forum/go_quote.gif
You are seriously suggesting the differences between screens are not measurable?
Colorimetry-wise, they will measure the exact same. That was my point, and I rest my case that trying to measure the SQ difference between opamps or cables using RMAA doesn't make any sense whatsoever. Try something a bit more advanced.
you do not need expensive gear to capture the differences between cables, as Nick_charles has shown. Doesn't make them any less inaudible though.
From what I've seen, his attempts at measuring the SQ difference between cables have been a major failure. Try a more advanced measurements package next time. Eating soup w/ a fork doesn't work, it never will.
Secondly, why are you using jitter as an example? We can measure jitter. There is absolutely no evidence at all to suggest that the amounts of jitter found in modern audio equipment is even remotely audible. For it to be audible, conditions would have to arise that caused the sensitivity of a listener to timing variation to increase by at least an order of magnitude. Obviously, if there was evidence to suggest this could actually happen it would have turned science on its head by now.
So all the data available about WM8804 is bs too? http://hifiduino.blogspot.com/2010/02/programming-wm8804.html
Wolfson have worked on its 50ps reclocking to only look good on paper in your humble opinion? They have more white papers on the right side of this page(even from the AES, God forbid!): http://www.wolfsonmicro.com/products/spdif_transceivers/WM8804/
Have you heard what a good reclocker can do before saying that jitter is inaudible? I bet you haven't. There are several WM8804 solutions on the market, and everyone I know who's tried them to reclock toslink to coax has been stunned.
Looking at the test you mentioned, he hasn't matched the volumes. This will result in genuine audible differences, that are ironically unlikely to be perceived as differences in amplitude. There are also tonnes of other opportunities for differences to result (the process he used is hardly procedurally perfect). Attributing them to opamps is an unjustified leap of judgment.
Have you listened to the two samples? Do they sound the same to you? This is an honest question, begging for a simple answer.
Non sequitur and one that is commonly used in all sorts of arguments on hifi forums. It looks different, it measures different, I hear a difference so that difference is caused by it. Wrong.
Not everything is placebo and not everything sounds the same, please stop pushing those exaggerated fallicies.
Well, it very much sequitur, I can tell you that. At least from where I stand.
In 4 pages times, I've been told that the quality of a pot doesn't matter, that the differences between opamps are so minute that they are inaudible(based on what real world experiments and in what conditions? God only knows), and that most DAC's sound the same too due to those minute differences between their output stages.
I like the diyaudio.com forum because it's full of ppl who try stuff, you know, the so-called "real world experience" and then they give honest feedback about what they've heard. A while ago, I found a comparison of PCM1793/CS4398 that matched exactly what me and other head-fi members have heard. Would you call it some sort of "collective hallucination"?
Once more, lookee lookee what I've found: http://www.diyaudio.com/forums/solid-state/169484-what-wrong-op-amps.html
OpAmps do have their own sound, the fact that we seem able to pick up on these tiny differences always amazes me, but we do.
Each OP-Amp type has it's own THD/IM spectrum, strongly independend from the layout and load conditions so as the quality of power supply
It's 24 pages long too, and I'm sure Scott Wurcer(the designer of many top of the range audio opamps, including AD797) must have given his opinion in there as well. Would you say that these ppl are delusional? Don't you find it a bit of a problem to talk about equipment you haven't heard? Roll some opamps, hear for yourself. If LT1028, AD797, OPA827, ADA4627 sound the same to you....well, at least you tried.
