Gluegun: Teeheehee - but I HIGHLY reccomend you actually try and listen to the speakers first, I have heard all kinds of PC speakers, and while my ear might not be as good as yours, I have somewhat easily definable tastes (Warm, smooth treble, deep and slightly punchy bass)
Yep - computers suck at imaging. Badly. That dosen't stop them from having fair imaging however.
For those of you with a system that has tiny sattelites, like the PCWorks and BA635, you can have incredible imaging (By PC standards of course), You need to hold the speakers in such a position as to be about 2.5 feet from your head, about 30 degrees to your side from straight foward, and have them point so the theoretical lines from the center of the speakers goes somewhere around/slightly behind your head. When done properly, the sound just hangs in the air, and it is very hard to tell where the sound is coming from. Tiny sats will do that. An idea computer audio setup would literally have the speakers wired to the celing and held at the perfect level.
Computer speakers tend to have a huge weakness, and that is the lower mids, and high crossovers because of their small size.
I have one audio setup, and it is my computer audio setup. The thing is - I am basically bypassing my soundcard with the digital out, and sound quality is noticably better on my consumer grade Yamaha reciever. I will be adding a Denon CD player soon enough which is replacing a portable CD player as my main CD unit. I use this system for everything - computer audio, critical listening (Well, most critical listening, if you could call it that using a portable CDP+airhead+HD600), and all casual listening.
So my computer is basically just one audio input for my stereo. With the real CD player, I will be able to turn the computer off and listen to music on my computer speakers like i have never heard.
I will soon redo my room based around my stereo first, and my computer second. I will need some speaker stands that are high enough, find a plce to put them and my computer, and I don't give a damn if the whole setup takes up three quarters of my room. I want the best sound I can get. and I am shaping my computer and audio system to me needs the best I can on my limited budget. I am even foregoing upgrading my PC for another year or so to do this.
Mind you, this is a pretty tricky feat. I need space for the computer, the 2 monitors, the reciever, CD player, speakers themselves, keyboard, mouse, other stuff like alarm clock (Although it is all easy). I can't use a corner setup because it won't leave me room for speakers on stands. Noone makes a computer desk designed with the storage of a computer, reciever, cd player, 2 monitors, and be built in such a way that I can have stand mounted bookshelf speakers either. If anyone has any good, cheap ideas regarding this, I am all ears.
I have gone through a few sets of computer speakers, and they can sound much different. The difference between the Altec Lansing ACS-48 and the Klipsch V2.400s is much more significant then the difference between a pair of Sennheiser HD600s and a pair of Grado RS-2s.
