BournePerfect
- Aug 25, 2010
My HD 800 sounds breathtakingly marvelous from my DP-1/ZDSE.
-Daniel
-Daniel
Ipods have a flat frequency response. Using the line out dock cable costing £3 into any one of my headphone amps the sound going into my hd800s is breathtakingly good
My HD 800 sounds breathtaking marevelous from my DP-1 ZDSE.
-Daniel
And here it goes...
@Takenidea, and the sarcastic answers :
Since all the fuss about this thread is related to the amp, and that the line out of dock allows to bypass the internal amp of the ipod, while using an external one,
I'm not sure why this statement (quoted below) could be disturbing.
Unless a 1000$ dac coupled to a 1000$ amp is even necessary( <== Look I've put the two icons for everyone.
Nicer as in sounds nicer? The frequency response of an ipod is above and below what a human ear can hear. The distortion is below hearing thresholds. Jitter , as in every half decent digital source on the market , is inaudible.
Therefore the ipod seems to be a transparent device which should deliver the music through to the headphones with a good degree of accuracy. As should a cd player etc .
Ever wondered why you couldn't hear much difference between cd players in a hi fi shop? It's because there isn't.
The amp is needed to amplify the sound is noisy situations but in a quiet environment shouldn't be needed. I live in a motorhome with loads of traffic noise around so I often need to amplify.
And as I've already got the stuff I may as well use it.
Do you mind explaining why my hd 650 coming out of my sound blaster x-fi sounds so dull and flat vs my burson amp and dac setup. Not just a little difference but it's like I went from OK sound to amazing. Could tell the difference in a blind test no problemNicer as in sounds nicer? The frequency response of an ipod is above and below what a human ear can hear. The distortion is below hearing thresholds. Jitter , as in every half decent digital source on the market , is inaudible.
+1
when i first got my hd 650 (they where my first headphone) i had them straight out of an x-fi card as well, and then i bought an amp for them (entry level pro-ject headphone amp), the different was night and day, like very obvious and immediately noticeable. then i added a DAC and the difference was even more obvious. and when i upgraded to my WA6-SE, it was another huge improvement as well.
