gregorio
- Feb 14, 2008
[1] I also need to make an aside comment about how "tests whose results we agree with may have a few unresolved issues" but "tests whose results we disagree with get debunked".
[2] That meta-test was based on the same data, from the same flawed tests, that everyone wants to use as "proof" of the opposite claim.
Therefore, unless there are actual flaws in their statistical methodology, it is no more or less valid than the tests on which it was based.
1. True to an extent but the tests I disagree with are those whose results are contrary to known and demonstrated scientific facts.
2. Again true to an extent. The Theiss study for example demonstrated no ability to discriminate but in a supplementary non-ABX experiment with 3 of the subjects, a very high ability to discriminate was demonstrated. There are several reasons to strongly dispute this supplementary experiment, not least that it wasn't double blind but the meta-analysis only includes the supplementary experiment results, not the main ABX experiments. And, if we're going to eliminate the M&M study on the grounds that some of the samples were not Hi-Res, as the meta-analysis does, then how come there are other studies included which had no Hi-Res samples at all because they were well before hi-res was even invented?
The problem we have here is also one of time/history. Is it possible to discriminate 96/24 from 44/16? Yes, it is! BUT, using the same criteria it's possible to discriminate 44/16 from 44/16! In it's early days, 44/16 had it's issues, today's 44/16 is quite different. If it were possible to do a direct comparison, I'd be very surprised if we could not fairly reliably discriminate early 44/16 from today's 44/16. The same principle applies to 24/96. There was a period of 5 or so years when it was entirely possible to differentiate between 24/96 and 16/44. A large number of plugin processors operated significantly better at 96kHz that at 44.1kHz (easily determined in DBTs) and in some cases this is still the case, some: Compressors, limiters, soft-synths, guitar amp/cab and other modelling plugins for example. So, 24/96 can be audibly different/better than 16/44 then, case closed! Hang on, not so fast! Filter implementation has improved significantly over the last 20 years, so has upsampling/downsampling conversion, due to far more available processing power and improved software algorithms. Today (and for nearly a decade) a plugin which benefits from a higher sample rate can simply up-sample to that rate, process and then down-sample again, with no audible loss/artefacts. There's no longer any audible benefit to actually recording or outputting the audio files at 96kHz, and 24/96 can no longer be discriminated from 16/44, unless a DAC/DAP manufacturer deliberately (or inadvertently) builds a difference into their design.
G
