yeah you told that to us almost word for word last page too. but you don't actually have any evidence of what you're saying. not for your opinion that highres sounds different(let me guess, sighted evaluation?), and not about music being any more difficult for 16/44 than redoing 1 single 20khz sine wave.
it could look counter intuitive to some, but that's how it is. the difficulty is not how many waves are recorded at once, because waves add up at one physical point into 1 single value of pressure in the air, and one single value of voltage in the analog path at a single instant T. so the hard part is only ever to be able to move from one value to the next fast enough to redo the content before the direction changes(up or down). and what is the fastest changing content of music in the 20hz-20khz audible range? the 20khz sine wave! all the music below is factually changing slower than one single 20khz sine.
so doing 20khz right is in fact evidence that we can do everything that is slower and your argument is false.
and this could be demonstrated(contrary to your statement). take super complex music from 20hz to 15khz, you can redo it with let's say 35khz sample rate(some margin for the low pass filter). but you will fail to redo the 20khz sine wave correctly with that sample rate because you won't have 2 points per period and the low pass filter can't save that.
no DAC is drawing a signal by adding points one at a time and leave it at that. until you understand the purpose of band limiting, you won't get what the low pass filter really does to the analog signal and you will stay with your false instinctive concept of digital audio. it's ok, I was like you, everybody here was like you and thought like you at some point in life. you can't know what you don't know. but you sure could consider that maybe you don't know as well as you think, after you see so many people and read so many papers contradicting your idea of digital audio.
if you find that boring to read, or didn't do much math or physics at school, it's very ok not to bother. I can drive a car and don't understand 90% of how it works
. there is no need to be a rocket scientist to enjoy music. and there is nobody telling you to stop buying highres tracks if you want to.
but if you come here telling others how things are, you have to know your stuff !
