cosmopragma
Rick, you are a man in the know as far as analog audio circuits are concerned, but computers-as-source audio doesn't seem to be your strong point.
There are shurely listeners out there that plug some cheap headphones directly into a soundcard, but hardly any head-fier would do that.
I do have the direct comparison between a hardware based solution (Corda Cross I) and a good software based solution ( headplug).Both have their strenghts and weaknesses.The Corda is a bit more transparent, and the headplug DSP effect is totally adjustable to your anatomy and to the specific needs of a song ( by imprinting the effect once into the file by utilizing the diskwriter function, no further need to fiddle around with sliders or knobs while you are listening to different songs).
The austrian programmer (Paul Groke) of the headplug plugin frankly admits that there's still room for improvement ( BTW by making it more complex, especially the dithering algorithm he implemented is too simple in his opinion.
I guess with a little fine tuning of the DSP effect it would finally render hardware based solutions inferior and useless at least as far as digital non DRM audio is concerned. Quote:
Maybe because it's totally free since the computer is already there?
Well, from my point of view they are pretty much locked into a hardware based solution so not only are options limited but direct hardware based/software based comparisons impossible.
Generally speaking you are generalizing your experience with analog circuits resulting in an "as simple as possible" approach and expand it to the digital realm where it doesn't apply.Complaining about "millions of calculations" is like a computer guy complaining about "gazillions of electrons" in analog circuits.
And a dozend of bad sounding DSP effects don't mean that the whole concept of DSP is flawed like ten weird women in your past don't mean to avoid women at all.
Originally Posted by rickcr42 If your entire audio system is "in the box" computer based with only the actual headphones being external you are prettty much locked into a software soltution so not only are options limited but direct hardware based/software based comparisons impossible. |
But think about it for a moment.Why would you want all the steps involved with either a stand alone DSP/CODEC ...... |
And what about those who still have quality analog sources ? Analog tape ? Vinyl system ? FM radio |
