But it's still a wide band. I haven't listened to the IE8, so I can't comment on them directly. No one has done frequency response and distortion tests on it, so again, there's no info stating what it does
well. We are left with user comments/reviews.
I can say the same about the RE0. 20Hz and 15kHz was there too. It's a really good wide band driver. However, sound being there and sound
correctly being there are two different things. An example in home audio would be the common use of a small 3" or 4" wide band driver in a compact satellite design. Ported, they can offer quite a wide bandwidth. For example a Jordon JX92S in a ported enclosure will output from 40Hz to 20kHz within +/-5dB, better with a little EQing. However, just because the frequency range is covered doesn't mean it's covered well, or I should say
as well as a multi-driver system.
The RE0 and IE8 do make good use of a single driver. However, you have to ask yourself is the quality of the information presented as good at 20Hz or 40Hz and 12kHz or 15kHz as good as at 500Hz or 2kHz? Is it as accurate and without noticeable distortion everywhere? I can't comment about the IE8, but the RE0, I can say no. The top end, albeit present, did lack accuracy and definition of the information presented. Because I have not heard the IE8, I can only speculate. However, physics and history lean me towards the idea that there will always be a compromise in a system that is limited to one driver. Still, great implementation will yield great sound. Yet, to say it's as good as a multi-driver system is stretching it.
The HD800, a different scale, a different price. Still, you're bound by what you can make work. Frequency response is there, 14Hz - 44kHz within 3dB. What about distortion? If it is amazing, I'd love to see a BL, CMS, and Le curve of it showing amazing linearity. I'd love to see a frequency response plot and distortion plots through the frequency spectrum.
Show me now amazing it is over the entire range.
Am I saying it can't be done? No. I'm just saying generally multi-driver wins. It's an easier approach, many drivers that excel over a narrow bandwidth paired together to excel over the entire frequency spectrum.
The closest thing I've ever seen to actual IEM testing:
http://www.hometheaterhifi.com/volum...07-part-1.html
I'd love to see more.
