Heidshade
- Jul 24, 2004
I found that the 4G U2 pod makes a background hiss when phones are plugged in, but silences when the player actually starts. By comparisom, my 3G pod is silent (noise-wise) always :lol:
Originally Posted by discord Ever see that movie White Noise? Yes, that's what's happening to you... |
Originally Posted by IZCool I've noticed the same thing with my 5G 60GB iPod through my Shure e5c earphones. There is a little background white noise, it doesn't worry me too much though... after starting the music, the noise is still there, but it doesn't worry me unless I listen for it. I'm impressed with the amplifier in it though, with the Shure e5cs I tend to run it at about 5 - 10% volume otherwise it's too loud! I guess one possible solution would be to put in a small resistor voltage divider (kind of like the Ety ER4P-S adaptor) and turn up the iPod a bit more. So you're not the only one EDIT: I think it's because of the high sensitivity of the earphones in question here, as you turn down the volume on the iPod, the constant noise (independent of volume) becomes more significant relative to the music. |
Originally Posted by mariowar IZCOOL, the reason why you hear it with this particular earphones is: 1- They are in-ear phones, they are prone to hear it because the closed and isolating feature. 2- They might not be low impedance headphones, but they are VERY sensitive (122 DB/MW), compared to popular Sony earphones MDR-EX71 (100DB/MW) |
Originally Posted by GhostWing But, putting a resistor between ipod and e5c will obvilsly affect the Sound Quality of e5c. Would you like to try: lower down the volume in ITUNES and reload the tracks to ipod? Will this enable you to set a higher volume on ipod? |
Originally Posted by IZCool I don't really want to resample my mp3s - if you do this you will lose quality and you're using less of the dynamic range of the DACs (thus making the sound closer to a square wave). If you use a voltage divider - two resistors per channel - you should not (in theory) affect the signal's frequency content, it should just reduce the amplitude - effectively an inline volume control stuck at one position. IMO everyone's overreacting here, if you listen hard enough on most portable (and some not-so-portable) devices, you'll hear some white noise, some more than others. The iPod's noise floor is fairly low. |
