Originally Posted by Iron_Dreamer
Yes, they do have very good bass, as is their performance all around, very good, nothing spectacular.
Most of the comments seem to suggest that they are something quite interesting, if subtle. Well balanced, smooth and silky at the top end while having excellent bass extension and slam. They seem to be clean while not being totally clinical in the mids.
It hits harder than the DT880
Originally Posted by J-Pak
Bass on the SA5000 is very thin
Hmm...
The review at
http://www6.head-fi.org/forums/showt...ghlight=sa5000 seems to suggest that bass does not have quite the same "force" as the DT880s. Again, like the mids it is perhaps more accurate, but if that's what I wanted I'd probably just shell out the extra for some low-end Stax, or just stick with the ones I have.
The other option is the DT990, or 931. The 931 seems like it could be the better choice from what I read. Less resolution and detail than the DT880s, but more bass. Although, people always say the 931s are better with a 120ohm adaptor, giving even better bass, so perhaps the 880s could benefit from a little extra impedance as well?
I think my problem is I'm not sure how much bass I need. What I mean is, I know I want more than the 495s, but how much more? I don't want too much either. I'll see about having a listen to some Grados if I can.
If I seem obsessed with bass then please excuse the impressive I have given. Mids, particularly vocals and guitars are really important too, as is the top end. I want something with some genuine slam and speed though. With power metal, drumming really sets the pace of things.
There is also Audio Technica. The AD2000s seems to be a bit warmer, a bit more exciting than the clinical SA5000s. Having said that, the Beyers still seem like a better choice.
I am not too familiar with the UK headphone amp market, but you should be able to get the parts for a PIMETA pretty easily. This amp sounds great for the money and can compare with the $$$ amps until you get a really spendy source. The X-can and Bada are both decidely mid-fi, but in all odds better than the OBH11 from what I've read about it.
I see. The OBH-11 was a big step up from the headphone jack on my Rotel RA-820BX2 amp. Would a higher end end headphone amp be like the same jump again, I wonder? I'll look into the PIMETA though, as I fancy building something.
