EricP
- Oct 29, 2004
I have to say that I posted a thread like this about a month ago and came to the conclusion that the RS-1 was what I wanted ideally for sound, but I was worried about comfort.
I now have the RS-1 and I can say with confidence that it will make the music that you and I enjoy sound great. Be aware that generally even though the level of technical ability of the players is very high, the level of technical ability of the producers is generally not, and you will get annoyed occasionally by the poor recordings and mastering.
As far as comfort, with the headband bent to fit my head, the RS-1, with stock bowl pads, is not an uncomfortable headphone. They are very light and if bent properly will just sit on your ears and not put any pressure on them.
Anyway, in my opinion, having heard the SR-225, 325, and 325i, the RS-1 is very worth saving up for. The RS-2 is supposed to be nearly as good, and is lower in price. However, if you buy used, you can generally get the RS-1 for under $500! Only $200 more than the SR-325i is more than worth the price of entry in my opinion.
