QRomo wrote:
Correction: removing any level mismatch removes one difference, the level mismatch. All other differences should be preserved. Perhaps we disagree on this point, but I don't think a volume difference is at all interesting on its own because it's equivalent to turning the volume knob on your amp. I'm more interested in differences that can change the listening experience.
It's not about what you find interesting or what you don't find interesting as it's about detecting the differences. Volume is one of the differences.
As for the "human biasing factor", I'm not sure what you're getting at here. Proper level matching is done with an SPL meter, not by ear.
The human, by finding need to level match, is adding their own personal brand of bias; "human biasing factor."
Perhaps my analogy was not the best, but your counter analogy is of the mark as well.
No it wasn't. It may not work for you but it's not off the mark either. Cut the rope, don't cut the rope, you're listening for a difference, no biasing of the volume allowed and if you're going measure and compare ropes, no cutting of the rope allowed.
There's also psychoacoustics to take into account. When presented two signals that are identical except for a small volume difference, people tend to perceive the louder signal as sounding qualitatively better when they're unaware of the change in volume. Indeed, it's a well known trick used by audio dealers to sneakily bump up the volume slightly on the more expensive component when a customer is doing a listening comparison to help sway their decision.
That's a straw man argument as there's no bumping of the gain going on. Set the gain on the amp and let the cables themselves carry the day. Cables are as neutral of an object as you're going find. They have no power source so they shouldn't be able to add or subtract from the listening equation, yet they do.
I'm surprised this is a sticking point for you, beeman. I think most people on both sides of the cable debate agree that level matching is necessary when comparing any two pieces of equipment. You're the first I've come across to object to the practice.
Personally, I'm surprised that nobody has challenged this point as it's as glaring of a gaff as the noon day sun in a desert, in the middle of August, in the northern hemisphere. First, you're not comparing two pieces of equipment. Why? Because you're comparing headphone cables and what is it you're comparing, the ability of one to tell the differences between the two cables. Volume is one of these differences and if you find need to level match, then you're admitting, before the test starts, that yes, there's a difference. No level matching allowed. And no switch boxes as the added boxes will mask over the difference custom cables make. We're now back to there's "never" going be a valid test, so folks need to just learn to enjoy, or not enjoy and stop getting their shorts in a bunch over what others, such as myself, are want to buy.
I'll even go one better. Let's assume that I'm all wet and cables are just that, totally bogus. If folks want to buy snake oil and buying snake oil makes them happy, let them. Anything else is just another case of folks sticking their noses in other people's business where it doesn't belong. I do draw the line at killing endangered species when products such as Viagra are commonly available.
(And if it lasts for more than four hours.....)
Oh, yeah, like I want to go walking into my doctors office with that complaint.
"Hey Doc., can you do anything for me?"
