It's not about what you find interesting or what you don't find interesting as it's about detecting the differences. Volume is one of the differences.
Okay, I see we're approaching the question slightly differently. You're discussing the more general question of "do cables make a difference?" where as I'm looking at it from the more pragmatic standpoint of "how do I determine if I hear differences between cables, and if so, how do I best go about identifying which I prefer?". So it's in that sense that I say volume differences aren't interesting.
That's a straw man argument as there's no bumping of the gain going on. Set the gain on the amp and let the cables themselves carry the day. Cables are as neutral of an object as you're going find. They have no power source so they shouldn't be able to add or subtract from the listening equation, yet they do.
It wasn't intended as a straw man, more an illustration of how psychoacoustics can affect our perception. If I'm trying to determine if I prefer one cable over another, I don't want to erroneously attribute a "higher quality" sound to one cable when it is really just slightly louder.
Incidentally, powered (or "active", as is the common term) devices are only required to add to a signal. Passive devices can affect the signal by attenuating and phase shifting (and maybe some other effects; I'm no expert). For instance, the addition of just a single capacitor and resistor to your headphone cable could act as a low pass (rolled off highs) or high pass (rolled off lows) filter, depending on how you wired it up. All cables exhibit some degree of resistance, capacitance, and inductance, which may or may not change along its length, so there's definitely a physical basis for believing cables can affect sound. The reason the anti-cable side contends a cable can't have an audible effect is not that it's not physically possible, but that the relevant physical properties of the cable are too small to matter.
Incidentally, powered (or "active", as is the common term) devices are only required to add to a signal. Passive devices can affect the signal by attenuating and phase shifting (and maybe some other effects; I'm no expert). For instance, the addition of just a single capacitor and resistor to your headphone cable could act as a low pass (rolled off highs) or high pass (rolled off lows) filter, depending on how you wired it up. All cables exhibit some degree of resistance, capacitance, and inductance, which may or may not change along its length, so there's definitely a physical basis for believing cables can affect sound. The reason the anti-cable side contends a cable can't have an audible effect is not that it's physically impossible, but that the relevant physical properties of the cable are too small to matter.
Originally Posted by beeman458 /img/forum/go_quote.gif
Personally, I'm surprised that nobody has challenged this point as it's as glaring of a gaff as the noon day sun in a desert, in the middle of August, in the northern hemisphere. First, you're not comparing two pieces of equipment. Why? Because you're comparing headphone cables and what is it you're comparing, the ability of one to tell the differences between the two cables. Volume is one of these differences and if you find need to level match, then you're admitting, before the test starts, that yes, there's a difference. No level matching allowed. And no switch boxes as the added boxes will mask over the difference custom cables make. We're now back to there's "never" going be a valid test, so folks need to just learn to enjoy, or not enjoy and stop getting their shorts in a bunch over what others, such as myself, are want to buy.
My guess is that people on the pro-cable side don't challenge this point because they're approaching the question in a similar manner as myself, and in that vein volume differences aren't meaningful.
My guess is that people on the pro-cable side don't challenge this point because they're approaching the question in a similar manner as myself. Since they accept that cables can make a difference, they're more concerned with differences in cables that affect the listening experience and level matching makes it easier to do this (and I contend should be done to eliminate the previously mentioned psychoacoustic effect).
I'll even go one better. Let's assume that I'm all wet and cables are just that, totally bogus. If folks want to buy snake oil and buying snake oil makes them happy, let them. Anything else is just another case of folks sticking their noses in other people's business where it doesn't belong. I do draw the line at killing endangered species when products such as Viagra are commonly available.
Agreed on this point. No need for anyone on either side of the divide to get all "holier than thou" on anyone else. I do find posters who take a non-dogmatic and thoughtful approach to the debate interesting to read, though.
(And if it lasts for more than four hours.....)
Oh, yeah, like I want to go walking into my doctors office with that complaint.
"Hey Doc., can you do anything for me?"
This gives new meaning to the term "cable discussion".
As an aside, I want to murder the head-fi post editor.
EDIT: On The Monkey's point, while I don't find volume differences to be interesting from a sonic standpoint, I do find it quite odd that they should exist in the first place. It seems to me that the cable and headphones form a voltage divider, and if that's the case the cable would have to have a pretty high resistance per unit length to be audible (assuming sane cable lengths). For interconnects, it would have to be ridiculously high. Hard to believe that anyone would use such a poor conductor in a cable. I've never noticed it myself, but I'm willing to believe the reports of others. There must be something else going on that's beyond my limited understanding.
