Originally Posted by snejk /img/forum/go_quote.gif
!!! That is a deadly sin in the hardcore Naim camp over at their forum! You HAVE to have at least two Fraims, the correct stacking order with empty shelves between cdp and psu and amp etc etc!
Haha. Yes. I seem to remember reading something like that before. The Fraim are so damn expensive but to be honest, if you're going to be spending 25-30k+ on a stereo system, you might as well get the Fraim as well.
The solid aluminium frame for the Chord Blu and DAC64 is also another one of those impressively expensive factory frames, retailing for around $2.5k, bumping up the total transport/DAC/frame price to just over $10k. I would hate to know how much the multi-level racks cost.
Naim maintains that the DIN connection is the best. The dealer in Hong Kong is tremendously confident about it and use stock Naim cables for everything. As a dealer for Audioquest, QED and PS Audio, you'd think that they would at least use basic aftermarket cables. I do believe that they use aftermarket cables for the other brands which they also carry (eg Vitus Audio, dCS, PS Audio, Oracle, BAT, Focus Audio, etc)
I have a Naim system which I am very pleased with. Did some demoing before the purchase and the naim system was the most fun and engaging system of the ones I listened to. They might lack in 'hifi' compared to some other high end manufacturers but I also think that this to some degree is a myth based on the characteristics of the older gear which I think were more flat earth oriented. |
Well Naim gear does not have the most neutral, uncoloured sound. I demoed a bunch of dCS sources and the hyper analytical dCS sound was very apparent. It was almost like I was listening to a different recording.
Speaking of the naim forum it is a great place where you can get good advice on buying and setting up a system. BUT it is also a very dogmatic place which tend to leave a bitter taste after a while. Using non-naim gear in your system is frowned upon (unless it's a LP12 or if it's gear that Naim doesn't manufacture, eg DAC). After hanging around at the naim forum for a while you learn the dogmatic do's and don'ts.... |
It's a great forum if you like Naim and have Naim gear in your system, or something British
