radrd
Found that torchiere lamps induce nicotine addiction in moths.
- Dec 9, 2001
No, but here is what you should do:
Listen to your HD280s with whatever you will have while you mow your lawn BEFORE you go out to mow your lawn. Set the volume just as loud as it is comfortable (normal listening level) while you are in the silent house.
Now, go out and fire up the lawnmower, and RESIST the temptation to turn up the volume of your music.
Assuming you don't listen at dangerous levels normally, you don't have to worry about hearing damage while you mow your lawn. Your music might not be loud enough, but at least you will be safe.
Personally, I say screw it and listen after I mow the lawn. I get pretty sweaty when I mow our lawn and I would rather not subject my HD280s to that.
will using my hd280s turned at a low volume mowing a lawn hurt my ears? |
