Originally Posted by TheMarchingMule /img/forum/go_quote.gif
My choices are:
1.) D40x w/ two lenses (one being the Nikkor 18-55mm Autofocus lens) for $800
2.) D40 DSLR w/ Nikkor 18-55mm AF Zoom Lens for $500
2a.) D40 DSLR w/ Nikkor 18-55mm AF Zoom Lens and 55-200mm G Nikkor for $600
3.) Nikon D80 DSLR (body only) for $900
3a.) Nikon D80 DSLR w/ Nikkor 18-55mm AF Zoom Lens for $1000
I looked up any future Nikon models potentially coming out...should I wait for them, or will they be that much of a difference from what I have above?
Many thanks for every opinion and comment!
I assume you have decided on one and purchased it?
In either case though, if I had to do it again, I would start at the D80, not the D40 or D40x (though they are DARN cheap right now). The D80 will have enough over the D40's to keep your upgrading urge down (camera body at least). The second you want to try a lens that requires an auto focus motor built into the camera, you'll have to upgrade from the D40.
And to be honest, you buy a SLR for the array of lenses. Why limit yourself?
I have no idea what type of photography you plan on doing, but I would get the D80 plus a nice little lens. That all depends on how much you want to spend on the lens.
If you can afford the VR 18-200, might as well. If not, the 18-70mm DX that everyone recommended is another good lens to consider, though you pass up on the VR and the extra range, but you save $$$.
Stop worrying about specs. Just get the better one, be done with it, and start taking some pics instead of wasting more time comparing the two (I mean..... really........).
From there, as you use your setup, you'll start to learn what other options would be helpful, and you can purchase them as needed.
Bottom line though, get one and start having fun!
Oh, and if you can, find a nice local mom and pop store and try them out. If you like the store, consider buying it from them to help support them.
I like BH photo for online purchases.
Kent does a lot of Nikon reviews at his site:
KenRockwell.com
