perplex
- Jul 9, 2004
Start with a D70 and 18-70 off ebay. Spend the savings on a SB-800. When I got mine I couldn't believe how incredible the little beast is. You just point and shoot, it's that simple
Originally Posted by yellafella321 /img/forum/go_quote.gif The main reason why I like the d70s so much is just the different approach to NR and high ISO. Its hard to explain, on cameras such as the d80 or d200 or d40, or the d300 even, at high iso's, edges look like they're kind of destroyed and reconstructed in a pixelated manner, where as on the d70s, edges remain the same, you just lose some detail, and gain some noise. Hope this helps. |
Originally Posted by TheMarchingMule /img/forum/go_quote.gif So far, so good. Judging from this forum: D80 vs. D40x: Nikon D80/D70/D50/D40 Forum: Digital Photography Review It seems that compared to the D40x, the D80 has: The D80 is worth every extra penny...you get, over the D40x: - An in camera focus motor - A top LCD (you may not realize how much you will like this) - Exposure bracketing - More dedicated buttons for changing common settings - 9 more focus points (11 vs 3) - Wireless flash control - 2 Command dials - Better battery life - Better build quality - Option to use a battery grip - A slightly larger, more comfortable to hold (for most people) camera -Several things I'm probably forgetting Unless your obsessed with the D40x's slightly smaller frame, the D80 is the obvious choice. It's not that much more than the D40x and is significantly better. The weight difference is negligable, especially after you have a lens mounted and I think most people prefer the feel of a camera with a decent sized grip on it. Hope that helps, Mark (from: Re: D80 vs. D40x: Nikon D80/D70/D50/D40 Forum: Digital Photography Review) Also, where is a good place to shop for lenses? I realize having only the camera body isn't the most fun possible. |
Originally Posted by Sherwood /img/forum/go_quote.gif The d40 also has a hi+ up to 3200, but that's not what I was intending to say. What I mean is that you can customize the camera's settings for when to bump up to a higher ISO. For instance, you can tell your Nikon that under low light, shoot at the lowest possible ISO until the shutter speed is above a certain point. That's what I intended by ISO threshold. Maybe this doesn't solve your NR and ISO problems, but it's a feature worth pointing out. |
