What is the sound quality of iPhone, iPad, iPod (Touch)?
Sep 7, 2014 at 9:57 AM Post #136 of 865
Near perfection at any rate.  To me spending money on outboard DAC's is pretty silly.  There isn't a bit of difference in sound quality between one DAC and another.  Hearing bias will work against your wallet to be sure.   Spend your money on transducers (speakers, headphones etc.)
Sep 7, 2014 at 3:55 PM Post #137 of 865
My Sennheiser HD-600's are high impedance (based on higher voltage) and require more than 1VRMS to get them to a "rocking out" level.
I use the O2 with my 5S and HD600's. As far as I can tell it simply increases the available volume. The presentation is so good that I am not interested in spending hundreds trying to improve it. I took on board the recommendation that I have read in Sound Science several times and sank all available cash into a pair of headphones. JH13's. With the 5S I don't think I am going any further.
Sep 7, 2014 at 5:23 PM Post #138 of 865
I had a set of HD590s and I read that they were on the edge of needing amping. So I bought an amp. No sound quality difference. It just made them louder. My current headphones (Oppo PM1) don't benefit at all from amping either. I just plug them directly into my iMac. Simplicity itself.
Sep 8, 2014 at 1:17 PM Post #139 of 865
To give a counterexample to the last two points, I genuinely did need an amp and a DAC for my Denon D5000s at work. How did I know? The (pitiful) headphone output from my work computer had a very audible hiss when not playing anything, and even at 100% volume, it didn't get nearly loud enough. An O2/ODAC solved both of these problems. Aside from the volume and noise though, the sound isn't any different.
Sep 8, 2014 at 6:30 PM Post #140 of 865
Although you say it's a counter example, you seem to have arrived at the same conclusion. No fundamental difference in SQ or soundstage, if I understand you correctly. Interesting that this is the case with the ODAC. How are you using the ODAC with the phone? I didn't think it would be Apple enabled.
Sep 9, 2014 at 12:14 AM Post #141 of 865
It's a counterexample because I did genuinely need an ODAC/O2 for my computer due to poor sound quality. It's obvious when it is needed though (and based on my understanding, the iDevices should not need an external dac ever, and should only need an amp with fairly challenging loads like an HE-6).
As for my ODAC, I use it with my PC at work. Sorry if that was at all unclear...
Sep 9, 2014 at 4:23 AM Post #142 of 865
Not unclear. I just need to read more carefully!
It's just that you say the sound did not change. I'm suprised you would be able to identify the sound quality through the noise and lack of volume.
Sep 10, 2014 at 11:14 PM Post #143 of 865
My girlfirrend is considering getting an Iphone 5s or an Ipod Touch 5G. I would like to ask a few questions...
1) Is there any noticable difference between the two in means of sound alone?
2) How do they compare with Cowon (I believe the Cowon sound is pretty much the same on all models)?
3) My girlfriend is planning to buy portable headphones (not IEMs or buds) to be used without an amp or any other external device, so will buying an Iphone 5S or a Touch 5G limit her options with headphones due to an impedance issue? Will these players be able to drive most portable headphones? I don't know anything about this impedance issue, so will you please enlighten me about the matter?
Thanks in advance for your valuable replies...
Sep 10, 2014 at 11:34 PM Post #144 of 865
I've heard Cowon D2 has capacitive coupled headphone out which rolls off sub bass.  Somebody at DIY section has replaced caps to flaten the response.
http://www.head-fi.org/t/638056/cowon-d2-hardware-mod-zning-mod
As far as output impedance affecting the iem has to do with the FR changes, dynamic driver iems are approximately flat impedance so it should not be affect by output impedance.  BA driver iems has skewy impedance characteristic.  With BA, the output of the DAP with skew if the output impedance is comparable to the impedance characteristic as in the case with SE846 with dip in the 5k which causes an EQ like drop of -2dB in that impedance dip(shown below) when matched with AK240 of 3.24ohm output impedance.
Sep 11, 2014 at 12:15 AM Post #145 of 865
None. All Apple products are audibly transparent. They don't have a sound. They present the music as it is. You need to make sure your headphones work with it well though, or you might need an amp.
Sep 11, 2014 at 12:50 AM Post #146 of 865
Not exactly.  Some earlier ipods had bass rolloff also.  Ken Rockwells graph of iphone is only resistive load or high impedance ultrasone 8.  Predictively flat since resistors or high impedance output are approximately flat.  No surprise there.
Sep 11, 2014 at 2:08 AM Post #147 of 865
I have the second generation iPod. No bass rolloff. Flat as a pancake. All of my Apple products are audibility transparent, going all the way back to the Mac 8500AV. Line out is what counts. Impedance depends on the headphones, not the iPod.
Sep 11, 2014 at 5:29 AM Post #148 of 865
Thanks for the answers. She's considering getting portable headphones (cans), so what is the impedance value that the cans should have at minimum and maximum so that she will not need an amp to use it with Iphone 5s (and the same question for Ipod touch, also) ?
