LORD570
- Feb 7, 2010
what is the difference between 32 ohm and 64 ohm??
i have 64 ohm headphone///
Originally Posted by David.M /img/forum/go_quote.gif not really much, other than the fact that 32 ohm easily connects to portable devices with ease. 64ohm might need a slight slight bit more juice. |
Originally Posted by LORD570 /img/forum/go_quote.gif what is the difference between 32 ohm and 64 ohm?? i have 64 ohm headphone/// |
Originally Posted by MacedonianHero /img/forum/go_quote.gif Unless that 64 ohm is a K701/2...then only a full sized SS amp will do! |
Originally Posted by Uncle Erik /img/forum/go_quote.gif No, a tube amp with low output impedance works fine, too. Headphone impedance is only important in the context of your amp's output impedance. There's a lot thrown around about how easy/difficult a particular impedance is to drive. However, you can drive any impedance well or badly. It all depends on the amp you use. |
Originally Posted by krmathis /img/forum/go_quote.gif 32 ohm . . |
Originally Posted by LORD570 /img/forum/go_quote.gif i have dj1 ultrasone .... its good or bad thew 64 ohm?? |
Originally Posted by Acix /img/forum/go_quote.gif External sound card, or DAC will improve the sound quality, and will give you a little more power to drive them. |
