Uncle Erik, I haven’t spotted that anyone has actually directly answered your questions.
So, against my better judgement, I’ll bite and try to do just that.
A while ago, I posted a positive review of a very expensive Transparent interconnect cable. So I’ll use that as my reference point for the following:
Originally Posted by Uncle Erik /img/forum/go_quote.gif
Suppose the manufacturer … admits that his entire business is a fraud. He laughs about how he just made up all the claims… and can't believe that people are stupid enough to fall for it. If that happened, would you still believe your cable makes a difference?
Yes, because the differences I heard were without any doubt to me, carefully taking all placebo, etc into account. However, I would certainly be very annoyed, and this would re-enforce my view that the high end of anything has ridiculously high margins, based on the product’s apparent material content. I wouldn’t buy from that company again and I might even try “rolling my own” if I felt I had the time.
Suppose a scientific breakthrough occurs where it is clearly demonstrated that cables do make a difference. That a method of testing is developed that allows cables to be evaluated for their sound signature and newer, better cables to be developed… Suppose the cable you own is scientifically proven to be one of the fraudulent models. If that happened, would you still believe your cable makes a difference? |
Yes, because the differences I heard were without any doubt to me. However, I would start to question how significant that difference was – i.e. whether I had made more of the difference than it deserved and I potentially could have found the same difference at a lower price.
I would also try to be open minded about the new measurements: The next time I was in upgrade mode, I would find the lowest cost cable that had as good measurements as my intended new high end cable. I would still let my ears be the final judge, but if the low cost cable sounded as good to me, then I would put more emphasis on trusting those new measurements in the future.
