WilliamLeonhart
I'm leaning toward returning the X2s at this point. Even though they are tanfastic. The momentum's have the added capability of travel (though I most likely wont wear them out too often) and are more comfortable. They do have that closed sound though (which is why im tempted to give the hd 600s a try).
If I amplify the momentum's too much via the Fulla, is it possible to damage them?
Why would you return them for examination?
Does the itchiness go away?
The crackles you mentioned. I'm pretty sure that crackling (and "pops") sound is never a good sign. See if they return in a few days. You should keep headphones at listening level (if you can hear it just fine, the cans can stand it).
The HD600 is significantly more refined than the Momentum, but they do need good amping (not just power but synergy as well).
